central heating corrosion
17 Sep 2009
Bradford
If no inhibitor is put in the c/h system. How long will it take for signs of corrosion.
That will depend on many factors, including the ration of different metals in the system e.g Copper, Brass, Iron & Steel,
Whether the system is pulling in air, and the quality of the water,
Some systems will corrode quite quickly, others will go years without problem.
However it it best practice and required by Regulations to clean and add inhibitor whenever a system is installed a or updated ;)
Signs of corrosion: couple of hours max.
What is it you are trying to find out?
just wonderd as i no some firms I have worked for before haven't had any put in.
Did the company uniform include a big hat and square toed boots?
