- Joined
- 29 Jun 2006
- Messages
- 86
- Reaction score
- 0
- Country
I may be doing some alterations to central heating in a bungalow. The bungalow has had a new combi boiler fitted six months ago. The flow and return go up into the roof space, and then there are drops in 15mm to each radiator. Everything works fine, however there is exposed pipework next to each radiator, which the customer doesn't like.
Does it seem viable to remove this pipework, run the flow and return down from the boiler under the floorboards, route it around the house and pop up to each radiator? I can't see any reason why not. My usual occupation is bathroom fitting, so I thought i'd just check incase there are any reasons why this wouldn't work.
Thanks for any advice.
