Central heating has been performing very badly recently, boiler and thermostat has been running fine but the water does not appear to be circulating into the radiators very well.
The bedrooms rads especially are only getting luke warm (they are on the ends of a long run of pipework)
Tonight I've made a vast improvment by going up into the loft and bleeding all the air vents I could find (helped a bit) and I also adjusted the speed on the central heating pump motor from 2 speed (which it was on) up to number 3 speed.
(it has 1, 2 and 3 speeds)
This is making the water circulate a little faster (with perhaps a little more push to the water) and it's now finally making its way to the furthest away radiators in the bedrooms.
Can anyone please confirm for me that it's ok to turn the speed of the motor up from it's number 2 speed setting, up to number 3 to move the water a little faster.
It won't do any damage to anything will it, or affect the motor?
Oh yes, it's a pump that looks like this:
http://www.tlc-direct.co.uk/Main_Index/Heating_Index/Central_Heating_Other_2/index.html
As it's just sitting on some chipboard on the loft floor, the motor pitch has changed a little and you can hear a different tone downstairs. It's not noisy, just rumbling the wood it's sitting on a bit.
But as I said, is it fine to turn the speed up 1 notch from 2 to 3 ?
