Now that I’ve turned the central heating back on after the summer, none of the radiators are getting even warm, apart from one in the bathroom.
I should mention that we are getting converted from conventional to combi in three weeks, so if it’s not worth bothering with, then I shan’t worry about it. It just would be nice to have some heating for the next few weeks.
We are getting hot water fine, and the boiler is firing up (although not for any length of time, maybe five minutes before it turns off - and it is knocking/kettling).
The pump is running, although it doesn’t sound particularly healthy. Pipes on either side are hot, and the pump is hot. Took the bleed screw out and no air came out, and the pump appears to be spinning.
Feed/Expansion tank has water in it.
Three way motorised valve is working (i think). When heating is on, the lever has no resistance to it. When hot water is on, there is resistance on the lever to move it to Man Open. The A and B ports get hot.
All radiators have been bled and only have water coming out of them.
Things i’ve tried:
Had pump running at all three speeds, with no difference.
Drained and refilled the system completely, with no difference.
Left the pump running and opened the drain cock on the downstairs radiator. (A plumber friend tried this when we had an issue with downstairs rads not getting hot. A lot of air came out of the system and it fixed in then). This time, when several litres of cold water had come out, the radiator started heating up, but none of the others did. On closing the drain cock, the radiator gradually went cold again.
I’ve been round the rads bleeding them every couple of hours, but only water ever comes out.
If anyone has any suggestions, they would be most welcome. I just don’t really want to spend any money getting it working if it’s to be overhauled in a few weeks time anyway.
Thanks.
Things i’ve tried:
Thanks.
