Hi, my central heating has stopped working and I could use some advice. Not sure if its related, but had a broken bath mixer tap which meant I had to cap off both pipes to it. Few days later, got cold and so started off the central heating for the first time this year. Heard the boiler start and the lights went o.n. Lots of loud banging from pipes and no heat to radiators/ no hot water. Checked there was water in two tanks in loft. OK. Checked pump running. Can hear pump. Attempted to bleed radiator nearest to storage tank, air hissing but not water. Checked all other radiators and got water as soon as i turn key. But no heat to any of them. Left it for a while, after 10 minutes hear bioler kicking in again. Lots of banging, little heat to the left hand side of the rad, turned the key to bleed and lots of air but still no water.
Have searched forums on noisy pipes, bleeding radiators etc but not found anything similar. Boiler does not have a pressure gauge so don't know how to check it? Any thoughts/advice most welcome. N
