Hello. forgive me if the following is poorly explained I’m new to the world of combi boilers.
I have an ISAR HE35 condensing combination boiler. Today I had problem with the RCD tripping as soon as the thermostat was turned up. Using hot water there was no problem, it was just for the central heating. So I turned the thermostat right down but I noticed that the boiler then continued to supply central heating (C was up in the status display) even though the thermostat wasn’t on and the thermostat on the boiler was turned down. Possibly the diverter valve is stuck on?
Another issue- recently -has been that there has been some condensation forming in the bottom panel just above the PCB (control box), I thought the outlet pipe might be frozen but it seems fine, any possible ideas here?
Thank you for any advice you can offer.
