Hiya
My family ( elderly Mum and Brother) used to have a back boiler but this broke down last week (leaking corroded heat exchange ) and the housing associating has replaced this with a Baxi Megaflo System Heating He a Range Gas Fired wall mounted Condensing Boiler.
Was installed Monday and finished by separate electrician Tuesday.
( replaced Gas Fire with electric Fire) .
Have same radiators but they fitted new valves and new radiator themostates? where you set the temp for that radiator anyway ( sorry I,m personally new to central heating myself) on all but the small hall way rad where the dial is also positioned on the wall to set temp, this was left on 20 but I have turned it up to 24 which seems to be about right.
What I wanted to know about though is the Central Heating Temperature Control on the actual boiler, all the manual info says is that is what it is, but no advice on how to know at what temperature to set it at , etc , the installers left it set at the max 80c. ( min is 25 - max 80c)
Using the temp controls on each rad for each room I have got the room temps about right, but the water is very very Hot , almost a bit dangerously hot, have it on for 2 1/12 hours alone with the CH in morning when is when it is mainly used, and lasts all day ( unlike with old boiler when it went cold or only warm after a few hours and often had to put water on again some evenings) .
Any advice on this would be very much appreciated.
At the moment have CH set to come on 6.30 am - 9 am , with water the same and CH only 6pm - 9pm, and use the boot on independant timer if CH is needed at other times.
( did have water to come on again first day but not since as really not needed)
Any advice on this or anything you feel would be useful regards this boiler would be most welcome, obviously want to be as ecconomicall as poss as both occupants are pensioners ( I am staying with them at mo for personal reasons)
Thanks x
Thanks x
