Hi, I have found many similar topics on google but don't seem to be able to find the exact same situation...
Recently our old potterton netaheat (semi-gravity) broke down so we have just had it replaced with a Worcestor Greenstar 12Ri and upgraded to fully pumped using a honeywell Y-plan pack. New cylinder and TRVs added to the radiators. Fairly small house with 6 rads.
The system is vented with an F&E tank in the loft, cylinder in the airing cupboard.
Before the switch we had problems with the F&E overflowing, with a constant dripping. which we assumed was just the ballcock on its way out (still think so). However after the upgrade things are a bit different.
When the hot water turns off, or when the pump turns off after the heating, there is a noise that sounds like water running through all the radiators, kind of sounds like a cracking noise almost the way it runs around the radiators, I had never knowingly heard it before the upgrade.
Initially this was also accompanied by a notable amount of water overflowing from the F&E pipe.
I called the installer back and he changed the ball valve so it doesn't overflow anymore. The water level in the F&E tank is much more sensible.
However the system is still venting some water, at least when the pump turns off. The noise still happens. I have tested this by turning the heating & hot water off and waiting in the loft a couple of minutes for the pump to turn off. I have put a bottle under the vent pipe to check exactly how much. The first time it was only maybe 1 - 3 fl. oz but I've left it there and will check how much is there tonight.
So I don't think this is meant to be happening... The system is installed in the correct order, boiler -> vent -> cold feed within 150mm -> pump -> 3 way valve. I don't think there's any bypass, but I see the boiler instructions say this is generally not needed.
Pump is a grundfos 15-50 and he left it on setting 3 when he left the first time. I have experimented with changing it down to 2 and its my impression that it seems to be less coming out, but I don't know if that is affecting it or not.
Should I worry about this? I believe this is generally bad for the system as it (probably fairly slowly at this rate) oxygenates the water? Any idea what the cause is?
Matt
Matt
