So built my garden office base, with 5x2 @ 600mm centres then noggins all the way across again at 600mm centres so when I lay my floor it will be sitting on little squares with every side supported but the old man just said "should be 14 centres so it will bow and flex everywhere" which has left me thinking if I use 22mm chipboard will I be ok?
This then leads me onto the walls... Was going to do these 600mm again so 1200mm pb sheet is fixed on both edges and the middle with a few noggins thrown in for good measures.
