hi
the cable rating indicated in the instuction leaflet is 2.5mm, yet the total wattage of all four rings is 6.0Kw, does this mean 2.5mm heat resesitant cable from the double pole switch or could i use 2.5mm radial on a 32amp MCB direct from comsumer box, via double pole switch, provided the cable is free from insulation in the loft so as not to increase it thermal heat in any way. The run would not exceed 5 mtrs.
