- Joined
- 16 Feb 2008
- Messages
- 3
- Reaction score
- 0
- Country
Summary: I fitted a new radiator in a 15 y/o Y plan system now steam comes from header tank when CH called.
The method:
1st i drained system to nearly empty.
i fitted new rad.
i bleed lower rads
i bleed upper rads
i bleed pipes in loft
for some reason i put 3 way switch into manual (?)
i switched heating on
warmed up nice
hot water too
i put 3 way switch to auto
worked fine for a day????
noises in loft steaming etc from header tank
pump ran for a while
now bottom rads cold but still dont need bleeding
upper rads hot - bleed one or two again
still sauna in loft.
i turned down boiler a bit.
Any ideas?
Looking at forums my guesses:
blockage in system - sludge?
What setting for 3 way switch / valve (man or auto)?
Conclusion:
Confusion!![Exclamation :!: :!:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The method:
i fitted new rad.
i bleed lower rads
i bleed upper rads
warmed up nice
hot water too
Any ideas?
Conclusion:
Confusion!
