- Joined
- 18 Aug 2004
- Messages
- 55
- Reaction score
- 1
- Country
This is lenghty, bear witt me.
I put some sentinal flusher in my CH system 4 weeks ago. Today I drained the system. I turned off the supply to the expansion tank and in turn drained from each downstairs radiator, opening the bleeder on all radiators eventually.
I then close all drainers and bleeders and turned on the supply. Water flowed into the expansion tank and I in turn bled each radiator, starting downstairs. On the 3rd radiator, the air stopped coming out half way through filling. I couldn't fill any more. Desperate, I filled a hose onto each radiator drainer in turn and filled from the tap. It worked but instead of seeing water flow back into the expansion tank from the supply to the system, it flowed from the expansion pipe. Also, I'm having to force water through the drainers of several of the downstairs radiators frequently as they "go cold".
It's obvious there's still a lot of sludge in their. How do I drain the remaining sludge further?
Thanks for reading.
I'm not a plumber and right now, can't afford one. Please advise.
Thanks for reading.
