Hi
Hope someone could assist me, Last week I decided to change a double gang socket from a wall mount to one thats inbeded in the wall.
So I've chiselled out the box hole and put in the new back box and wired the previous socket identically to how it was previously.
I then tested it and it worked fine, however when I switched on the socket that was nearest to it that plug made a noise then switched on, whereas the new replaced one switched off.
Ever since then no plugs in that room have worked, I have double checked the wiring in each of the plugs and there are no issues, but when I put a socket tester in, the replaced socket is showing LIVE & EARTH REVERSED (which is wrong), and on the other socket NO NEUTRAL.
So I'm puzzled, everything is wired up correctly but nothing works
any tips
any tips
