Hello,
Not sure this is the right forum, but I'm wanting to know some info on channeling into a wall to run conduit...
Basically I want to put 2 20mm plastic conduit tubes in a wall so I can run cables from my lounge into the loft. I have already installed the back box. Is it ok to cut a channel 40mm wide x 20mm deep to run this plastic conduit? This won't affect the structure of the wall will it? I'd like to cut 1 single wide channel and run the 20mm conduit in parallel.
My Walls are double brick cavity filled with render and plaster on the internals. The reason I want to run 2 conduit tubes is I have lots of cables I want to get into the lounge for audio, video, satellite and networking!
Any advice would be appreciated.
