Hello All,
I need to chase on both hot and cold water pipes into a masonry wall and run from ceiling to floor. There is not an option to box these pipes in.
I will chase a slot big enough so a pipe clip can be used, but is there any further noise prevention that can be used?
Wall over the top will be cement board then tiles. No joins will be in the submerged part of the wall!
I was of using expanding foam to surround the pipework and then trimming it flush to the wall before cement boarding.
Bit I do not know if this will have any adverse effects, possible even making the noise worse?
Any help or advice will be much appreciated. Thanks in advance.
