I have a Keter garden store which only houses the lawn rake, so there's a large amount of unused space inside.
I have a small lean-to greenhouse which is full of empty plastic pots. I want to put a full-size shelf across the empty space in the Keter to store the pots on (as I want to use the greenhouse to over-winter plants!), so the shelf doesn't have to bear much weight, but being 1100mm x 750cm, needs to be able to support its own weight without sagging down. It also needs to be relatively cheap!
Note, I can support the shelf at both ends, obviously, but only at the back in the middle as a front support would prevent me getting the lawn rake out.
The inside of the store is dry but obviously it's outdoors so a small degree of water resistance is needed.
Any ideas?
Ta.
Any ideas?
Ta.
