My 1930 chalet bungalow has a long-standing problem with damp leaking in around one of the chimneys. After taking advice I have had the chimney rebuilt with lead trays and new soakers but still have a problem with damp seeping in around the back gutter area. This photo shows the roof and East chimney:
View media item 47980
Out of frustration I opened up the tiling at the back of the chimney a few days ago and here is a picture of what I found:
View media item 47981 You will note that the roofing felt runs under the back gutter (which you can see the top edge of) rather than over it. My understanding is that this is wrong.
I believe (verified by tests) that the cause of the continuing damp is that wind-blown rain is working its way under the tiles above the chimney and then running down the roofing felt, under the back gutter, and into the house. The big question is - How do I fix it? I have looked at lots of information but found none that shows clearly how the tiling, felting and leadwork should be arranged in the back gutter area with my sort of tiled roof. If I try and bring the felt up over the rear of the back gutter it will run over the wooden edge that supports the short tiles, and will have nail holes for the tiles through it as well. This seems very wrong but I can't work out what is right.
Any help very much appreciated. More photos can be provided if required.
