Solum ? that's under the ground floor ?? You talk from 2 inches behind your scrotum.There's a definite back gutter but the flat bit (the solum), .
I cant clearly make out whats going on ?
No **** SherlockThe cause of earlier confusion can now be seen - .
(the solum),
You want trussing, tel - in a calico strait jacketthe roof was then framed & trussed .
Your pic shows what you should have - and it should be high enough up the brickwork to run onto the Tiles @ the sides.Hi all,
e!![]()
