I, for one, am not an (electrical) professional Anyway, an attempt at a translation ...professionals talking and I didnt understand a word. ... .but it sounds ominous!
Someone suggested that replacing your whole CU might be a bit OTT. I therefore said that you might ask your electrician whether he might be able to just replace the case (which comes with terminal bars etc.), re-using most of the innards of the present one. TTC suggested that might not be as easy as it sounds, because of the apparent make of your CCU - which may be true. Your electrician would know.
Finally, I mentioned the fact that your current CU, with just one RCD and some circuits not protected by an RCD is an old-fashioned concept. For a new installation today, current regs would more-or-less require a CU with two RCDs - so I was suggesting that if it did need to be replaced, your electrician might well advise you to have it replaced with a 'current regulations' one (even though that is not mandatory).
Kind REgards, John
