Circular Saw - Black & Decker KS865KN
10 Feb 2010
Hello, I bought a replacement blade, a Bosch Standard. 184mm 20/16mm 40point, for the B&D KS865KN, and was assured it would fit, I do not have the original blade to compare.
I have tried to fit the blade to the Saw but it just does not seem to sit over the inner washer. can anyone advise me of the correct order to do this please?
Thank you.
I did a quick scout round the net and the manual for your saw does indeed say 184mm diameter x 16mm bore. If your blade is bored 20mm there should be a 20mm diameter bushing to fit into the centre bore of the blade which will reduce it to 16mm. It'll look a bit like a thin washer. If it's not in the packaging get onto the supplier to request one
If it will not fit then probably best to take the saw with you to the shop. If I remember right they are not the standard so you have to buy there blades at B&Q.
JobAndKnock.Thank you for that info, I don't suppose you remembered the link to the manual did you?
There was indeed a washer stuck in the packaging of the blade, and this did fit into the 20mm bore. so things seem to be o.k. now, although I have not replaced things yet. (the manual would be interesting though?
catlad. I did go to B&Q but they do not stock B&D saw blades anymore, just Bosch, I have found a B&D supplier locally, but thank you anyway.
Thank you both, I think that between you, you have sorted me out, thanks again.
