probably tank fed from storage tank. look for big tank with two 22mm pipes coming off it. trace pipe to valves. if no valves , turn off the main and open all taps until water stops. fit isolation to toilet and refil. if this doesnt work, look for a second main, as some older houses used to have a main at the back of the house for the outside loo.
