Clio elec fault
14 Sep 2006
Liverpool
15a fuse feeding cigarette lighter and radio in my daughter's Renault Clio (2007) has blown.
Resistance from fuse (load side) to chassis showing 8.4 ohms.
Tried a 20a fuse (it's all I could find) and it popped instantly (no cigarette lighter in).
Cleaned out lighter socket, but still shows same resistance.
Any clues ?????
I've had a few instances where an accessory has been pushed too hard in to the fag lighter socket, causing the damage you describe......it's probably a good idea to remove it from the dash for bench testing before fitting a replacement.
John :)
  • Thanks
Reactions: SNM
