My beams needed to be adjusted for the roof line. Is this an issue?
When does a cut out become too much?
Thanks.
Thanks.
I would agree with some of the earlier posts that a steel beam should sit on a concrete padstone at each end. I have never know steelwork to sit on timber and structural engineers always specify steel beams sitting on masonry walls should bear on to dense concrete padstones ,in addition they specify the dimensions of the padstones to suit the loadings on the beam and the compressive strength of the blockwork or brickwork the padstones sit on.
I thought that initially. Rather, it looks more like where he has nicked the plate with the angle grinder whilst attacking the end of the steel.Especially as I think I can see the steel sitting on top of the joint of two separate wall plates
I suspect that if the wall plate got damp and rotted, the OP would have more important problems to worry about!Tony,
Fully agree with your maths.
But looking at the above photo I would be worried in case that wall plate gets damp and rots at some point in future.
Especially as I think I can see the steel sitting on top of the joint of two separate wall plates.
SFK
I'm guessing he didn't. I'll wager it was an on-site decision to position the beam within the floor space. Designer prolly had it down in to the room below.Who the hell designs a beam to stick out of a roof?
