Hello everyone, I was hoping to get some advice on how to proceed with finishing off our windows.
We had windows changed and moved forward so they sit flush with the outside wall. We’re left with cavity on the inside, which mostly have battens in the cavity gap (left, right and top side).
Decorators used additional battens where needed as openings were asymmetrical and fixed plasterboard to create reveals. I’m worried though that not using insulation (kingspan or plasterboard with insulation) to prevent reveal getting cold and creating condensation will cause us issue. What would be the right thing to do? Reveals aren’t plastered yet, so if I need to take the plasterboard down now is the good time.
In case above is ok and insulation is not needed, should we use something to close cavity before sill is fitted (definitely a gap there as per picture)?
Pictures before and after reveals we’re fitted. Thank you!
