Hello all,
I've done a search in the forum and I know this is a recurring issue but wasn't sure if it was boiler specific so thought I would start a new thread.
I have a Potterton Flamingo RS13 boiler (which I believe is circa 70's) so it's not exactly a new system.
I also have an immersion heater and water tank upstairs which supplies our hot water.
Thought I'd give the boiler a fire up just to make sure everything is ok and the downstairs rads are stone cold, as are the pipes connected to them. The upstairs rads are heating up quickly and nice and hot.
One thing I will point out is that last winter I tried to balance the radiators and the flow valve on nearly all of them started trickling water so ended up with all flow valves on all rads fully open (and tightened) to stop the water dripping which gave us heating throughout the house.
So firstly and only at the moment I have bled the rads to dispel any air an that's where I am.
Q1. Will having all the rad valves fully open cause the downstairs rads to be cold, even though this didn't occur last year? If so do I need to turn upstairs off and see if downstairs gets hot?
Q2. If not, and I need to be looking at the pump, where the hell is it? It's not near to the boiler and it's not in the cupboard where the water tank is. So without wanting to pull up the floorboards upstairs, is there a logical route away from the boiler to follow to the pump?
Hope the above makes sense and any help would be great.
