hi again, try it with a good adjustable spanner, and give it a bang with the palm of your hand in a anti clockwise direction, or somthing a bit "harder" if you dont want to hurt your hand, get a MAN to do it for you
Try checking the pump or have someone check it, normally more than one rad though... could be a balancing problem though, try turning off or down all rads except this problem rad.
Thanks go to Bucks 51. I got an adjustable spanner, banged it a few times with my hand and finally managed to get it to turn. Lo and Behold I now have a hot radiator. Thanks for the help and advice. much appreciated.
that's a new one!! never knew banging an ajdustable would help open a nut/spindle/valve! Might have to try that in future if a tap headgear nut is stiff and won't budge! I suppose it shocks it out of position and loosens it?
Your more than wellcome thank for letting us know its sorted
Well you learn something new every day, dont you Liverpool Boy
I hope Goldspoon sees this!!!
