My daughter has recently moved house. actually it was 2 houses converted into one.
There are 2 combi boilers one in each cellar, which appear to be linked together.
However my FIRST query (or plea for help) is:
There are 2 radiators in the kitchen which won't get hot.
The scenario is .....flow & return pipework to these radiators comes from the cellar onto the first floor, and then down the kitchen wall where it is branched to each Rad (about 12 inch of piping) and is at the end of a reasonably long run
One of the rads has a drain cock, and I have checked the flow of water through each pipe, and it seems OK.
I suspect.. that these rads are at the end of a long run, and there may not be enough flow to allow water to circulate (haven't had chance to close all other rads to test this theory)
OR does anyone else have any ideas
PS> Both rads have been bled on numerous occasions and there is no air in them
