cold water as a result of Mains pressure drop
22 Feb 2005
Hello
Wonder if someone can help!
My house runs two boilers - one for central heating , the other for the hot water system. This latter boiler works off Mains pressure.
As Thames Water has significantly reduced Mains pressure to control leakages in London, water hardly gets warm.
I could use some advice on whether installing an auxiliary pump to supplement the Mains pressure is a plausible option and if so how can this be done?
I would really appreciate some help, please.[/img][/b]
First of all contact thames water & get them to do a pressure & flow test on your supply to make sure it's up to the minimum standard, if it's not the next step is for them to dig up at the boundary & check it's OK there. If it's not then they should give you a new supply if it's lead, or a new conection at the main if it's copper or plastic. if it is lead going in to the property then the best bet is to relay it with 25mm MDPE. Hopefully this should improve the problem with the water heater,if not your stuffed I'm afraid.
Hi
Thanks Keego for such prompt reply.
I shall take on the advice.
