What size washers are best to buy, and in what size, for tank connectors to a cold water cistern in the loft? The tank connectors are 22mm and 15mm diameters. I know you can use rubber washer or plastic (polywashers)?? but would like to get the correct size first time instead of having to go back and forth!.. Any good types from your experience? Also is it good to have one washer on the inside AND one on the outside of the tank, or is 1 on the inside sufficient?
any help would be great.
