Download a copy of the installation and commissioning instructions from the Vaillant web site. Study this, and post for explanations of anything significant that you don't understand. You can then follow the installation procedure from an informed point of view.
The things most likely to be skimped on in a combi installation include:-
1. Thorough flushing of existing system to remove corrosion products and other debris that could cause damage to new boiler, using appropriate cleaning chemicals and finally inhibitor - this alone could take a day.
2. Replacing existing 22mm hot water pipework to 15mm. If 22mm is left in use, hot water will take longer to reach those taps supplied by it.
3. Upgrading gas supply pipe to ensure inlet working pressure of 20 mb.
4. Proper commissioning including checking gas pressures, flow and return temperatures, hot water flow rate - ensure Benchmark form is properly filled in with accurate data.
5. Can anyone add anything to this list?
