Combi Overflow prpblem
14 Nov 2007
Clwyd
My Glow worm combi boilers overflow pipe as started to run
What is the problem ??
How do I sort it
Great web site forum
If it is doing it whilst the pressure gauge is below 3Bar then probably a worn prv.
If pressure is above 3 then it is doing it's job and the fault/reason the pressure is going above 3 needs to be found asap.
Look in the FAQ Plumbing Tips topic for more on expansion vessel problems.
Thanks for all the ideas
The fault turned out to be the that the top up tap (the one you open when the red light comes on) had not been closed completely
Once again thanks for the replies
