Combining two hall single switches into one double switch
15 Nov 2006
I currently have two single switches in the hall to control the hall and landing light and have one double switch upstairs to control the same. All are obviously 2-way switches.
The switch for the hall light downstairs is in an inconvenient place and I wish to move it to where the other downstairs switch is located to give me one double switch. I presume I will simply extend the cable to the new location and replace the single switch with a double switch.
Questions are:
i) is it ok to do this? Is there a better way?
ii) what sort of connector do I need at the point of extension (presume I have to get rid of the unwanted switch?)
iii) what is the best way to run the cable?
Thanks in advance!
You will have to have a junction of some type where the switch is now and you will also have to have something to mark the end of the safe zone at that point as there are cables in the wall. So why not change that switch for an intermediate and take triple and earth from there to the new double switch.
Can't advise on how to run the cable without more information.
Thanks for the reply. Since the intermediate switch is simply a type of junction, is there anything I should be aware of when connecting the wires (although it sounds straight forward enough and instructions should be provided anyway)?
