- Joined
- 27 Jan 2008
- Messages
- 23,751
- Reaction score
- 2,679
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I know I have a slot but does it actually exist? Would kind of make a mockery of the name Freeview if it did I suppose, so I will guess not in the UK.
Since I have not got Freeview set up, no aerials as yet can't check. If I do set one up it will be aimed as Miss Piggy at Moel-y-Parc so if only in some areas that's where I aim aerials.
Seems RAYNET in this area has died so was considering using my now redundant radios from home, and it would make sense to use my HB9CV aimed at GB3MP at Moel-y-Parc so wondered if worth putting up a TV aerial at the same time aimed same direction.
But unless I can either kick Sky to touch or get programs worth watching not available on sky basic package then not worth the effort. Tried in door aerial but gets moved every time we close curtains and the old loop aerial is just on the edge to be able to receive. I had expected better I can open Miss Piggy with a hand held at 5 Watt so expected to get TV with a screw driver stuck in aerial socket. It is line of sight from my location and about 10 miles away. May be we pick up off back of an aerial here above Mold?
