Compatible replacement actuator : myson mpe322
Discussion in 'Plumbing and Central Heating' started by shmelv, 6 Jan 2012.
  1. shmelv
    2 Dec 2010
    33
    Thanks Received:
    Bradford
    Country:
    Does anybody have an idea which if any actuators are a direct replacement compatible with this myson mpe322 3 port actuator ( also called act322 I bleieve)
    Is there a sunvic actuator that fits or another .
    Cheers
  2. 45yearsagasman
    14 Mar 2010
    5,894
    Thanks Received:
    1,036
    Norfolk
    Country:
    As far as I know the Potterton / Myson are the only heads compatible with that body. They are not the best and you can buy the complete valve and head for £36. I would change the whole valve and fit a Honeywell.
  3. Agile
    26 Jun 2004
    61,313
    Thanks Received:
    4,286
    London
    Country:
    I agree.
    For a customer I would change the head as thats cheaper than having to drain and change the whole valve.
    But for myself if I had the time then I would fit a Honeywell valve.
    The motor only can be changed on the Honeywell ones but on the Myson its difficult and usually the plastic bits have failed anyway.
    Tony
  4. Cpplumber
    4 Jan 2012
    55
    Thanks Received:
    9
    Surrey
    Country:
    Another one to add to the Honeywell suggestion!
    Easy to obtain new motors and heads if ever required.
    Carl
  5. Boilerman2
    10 Jun 2009
    5,229
    Thanks Received:
    1,011
    Suffolk
    Country:
    I did manage to fit a Danfoss actuator to one of these valves once - BUT it was a lot of work including the need to drill new mounting holes in the valve face plate - not something i would recommend
    when getting a quote for a new head ask for the price of a complete valve/head assy as for some stupid reason they are often cheaper when bought as a complete head/valve - you can simply take the new valve off and just use the head on your existing valve body ;)
  6. muggles
    28 Oct 2005
    8,265
    Thanks Received:
    1,389
    Oxfordshire
    Country:
    Why do you want to have a different actuator? Why not simply buy another ACT322? I had to replace an ACT222 this week and my local Parts Centre had two in stock.
Loading...
Share This Page
