CAN ANYONE TELL ME HOW TO COME AWAY FROM A SLOTTED CONCRETE FENCE POST AT AN ANGLE THAT IS NOT 90 degrees. ie...A SLIGHT BEND, I AM USING 8FT POSTS & 6X6 FENCE PANNELS
I would get a length of treated timber the same height as the panel and the same thickness as the fence panel/slot 2" x 2" ish should be OK and plane or cut to the required angle along its length. Then screw this to the end of the panel (angled face to the panel) This will then allow the square edge to sit in the slot but have the panel at an angle.
