condensate fitting in wall
9 Aug 2009
Blackpool
the condensate is in a wall chase which will be behind the dot and dab plasterboard. the condensate will then go in to a 32mm elbow exiting the building through a 2inch cored hole so not on show. So the one side of the 32mm elbow will be well in to the wall. Is this ok, because they won't no pipes on show.
So its ok that you d d never know if was leaking, would glued be better than push fit?
