My condensate pump used to make a noise every time it ran, but recently the noise has stopped. The boiler is working fine and I've tested the central heating. Should I be concerned?
most boilers only condense when in ch mode if you are only using HW then this is normal, some do condense in HW mode which make and model of boiler do you have ?
Summer as per what ian says
but you can usually pour some water into one of the openings in the pump to test it
check the electric plug on it has not been disturbed
