Condensing boiler not staying at max temp
20 Jul 2009
Essex
I have a Vaillant ecotec condensing boiler and we seem to be getting variable heating results on both central heating and hot water tank recently. The boiler will switch on start heating the water, get up to 65deg target temperature, then immediately backs off and the water temp drops to about 45deg, the boiler then is content to keep heating the water at this lower value. To a layman, I would expect the boiler to run continuously at 65deg until a control like the hall thermostat tells it to turn off cos the house is warm enough.
Press the i button when the boiler is running at 45c and post back what the display says .
Or it's a 4 series and hitting target temperature during the ignition phase. Which model ecotec is it?
Could be an old wilo gold, still get plenty of new installes running one of they old bad boys, just not very well
