Posting here following DIYnot's advice on Screwfix - The topic of boiler reliability seems to crop up regularly on this forum since there is little information officially available on which boilers cause problems - particularly relevant now that more expensive and complicated condensing boilers have to be fitted. Here's my two pennorth worth - I had a Baxi 130HE fitted a couple of years back. It failed about six months in with a gas diverter fault - I diagnosed the problem with the lead and contacted Baxi who sent an engineer without the replacement part. As a backup I had ordered the part from Baxi also - it arrived some 10 days later. Eventually it was fixed, took all told about a week.
Out of warranty the same part failed again, so I investigated myself. The lead contains some electrical components and is potted, presumably to keep moisture out - but it doesn't, and unfortunately the manual bleed valve situated above it had been dripping. I fixed the damn thing myself using the lead I had originally ordered - next fault was the flow switch leaking, guess what, it's just above the same lead so it blew again. Built my own plug up which has worked successfully for some time but it would now appear the diverter valve itself has packed up. Baxi's attitude is poor - they'll charge a mint for a callout but aren't interested in keeping me happy given the number of failures on such a young boiler. A Friday afternooner? Does anyone else have some input on this?
PS I understand DIYnot's comments on boiler repair, but seriously is a Corgi registered plumber going to be more familiar with the components making up the diverter interface than me, a degree level electronics engineer? When I have no hot water, what do you think I'm more scared of, the regulations or my missus?
