Connecting monobloc tap tails
Discussion in 'Plumbing and Central Heating' started by garrymum, 25 Mar 2010.
  1. garrymum
    16 Sep 2004
    653
    Thanks Received:
    5
    Leeds
    Country:
    Hi
    Fitting new kitchen sink and taps tomorrow. Current layout of pipes is as the following picture. 2 x 15mm copper pipes connect straight to the existing monobloc tap.
    [​IMG]
    The new tap has the following tails, smaller end screws into the tap. All tap connectors I have found already have a big nut on the end. These new tails look to need a tap connector with just a thread and no nut.
    Thought I could get a couple of washing machine isolater valves like those in the first picture but they are too big, the flexi hose connector is too small. The diameter of the nut on the new flexi hose is approx 22mm.
    Or, am I missing something?
    Thank you.
    [​IMG]
  2. seco services
    3 Dec 2007
    15,656
    Thanks Received:
    1,248
    Essex
    Country:
    just use a couple of ballofix valve they are 1/2" thead.
    w/machine valve is 3/4"
    [​IMG]
    • Thanks Thanks x 1
  3. glasgowgas
    19 Mar 2009
    2,590
    Thanks Received:
    257
    Glasgow
    Country:
    the large nut will fit onto a 15mm compression straight (with the nut and olive removed) ;)
    • Thanks Thanks x 1
  4. garrymum
    16 Sep 2004
    653
    Thanks Received:
    5
    Leeds
    Country:
    Thanks both. Will get a couple of isolating valves tomorrow.
  5. neds
    18 Nov 2007
    929
    Thanks Received:
    28
    Country:
    Now how long would it have taken the plumber to wipe off that excess flux from those pipes! makes me cry :LOL:
  6. sophier
    19 Jan 2011
    Thanks Received:
    London
    Country:
    Hi
    I have exactly the same fittings as Garrymum's picture. However, I have been supplied with copper tap tails and I need to know how to connect these to the existing pipework. There are no connectors, valves etc shown on the picture. I know everyone says to use the flexi pipes but I understand that you can get wobbles. It's a steel Ikea sink.
    Any help welcomed. Thanks :)
  7. Morris40
    9 Jan 2011
    231
    Thanks Received:
    29
    Middlesex
    Country:
    as stated before flexi's onto ball-o-fix isolaters will do fine, you can connect copper tails to old copper pipe with ball-o-fix isolaters or solder no 1's but don't forget to still fir isolation valves, it's a must :)
Loading...
Share This Page
