I've given up trying to find a solution to get a 32mm sanicompact waste pipe outside so am going to commit to finding a route through the house to the 110mm soil pipe.
Problem is the only access point is a 60mm high vertical portion of pipe and only one side of the pipe is accessible (the branch for the toilet blocks one side and a floor joist the other). It would therefore be impossible to attach a strap boss without pretty much dismantling the house.
So my question is - can I get a decent seal from the 32mm pipe into the soil using something like this and solvent? Or some other solution that doesn't require access to the whole circumference of the pipe.
Importantly the only connection higher than this point in the house is for a bath&sink so no solid material could cause a blockage in what will be a non standard fitting.
Many thanks
Many thanks
