Connecting utilities to a mobile home
22 Jan 2012
Worcestershire
What prep work can I do to enable the utilities to be connected to a mobile home situated in the grounds of an existing house and about 30m from it. The plan was to connect Electric/Water/gas to it from the main house. The mobile is new and has a 100amp fusebox and can run off mains gas or lpg.
I really want to know if I can shave some pennies off the final bill. I have no intention at all of connecting any of the utilities myself either end.
Thanks and apologies if its in the wrong thread
IHNI about water. Guess you'd need BR approval to connect into drainage, plus authorisation from your water company/sewerage undertaker?
Gas - easy - you'll need an RGI.
Electrics - you'll need an electrician and you can do whatever prep work he is happy for you to to - they key thing is to agree that first, not present him with something you decided to do upfront.
I don't know what the load of the mobile home is, but if it's too high to be added to the house load you'll need a new supply for it:
Thanks to the last.....I have a foul water sewer running inside the boundary of the plot....I was really wondering whether electric-Gas-Water could share the same trench?.....The mobile home is rated to 100Amp. I did wonder if I would need a 2nd phase for the electric.....I was hoping not to !
You can't just create a new connection into it without asking, and you may find that you can't use it for surface water runoff any more.
Probably, subject to mimimum separations.
That doesn't mean that it's a 23kW load.
Get your electrician to calculate the demand, then you'll know. Will there be any large loads in it - electric hob, comprehensive electric space heating, instant water/shower heaters?
Thanks again....Its got electric fire, electric hob, gas CH, electric shower. I will do some research on trench depths. Cheers
Does the fact that it's mounted on a trailer still make a difference?
Still no TNC-S (PME) earth will be allowed to the mobile home. You need an electrician to assess your earthing type as well as the other factors mentioned above.
