Hello, please take a look at these photos and see if you can help...
its an old CU which I am going to replace with a new one, pretty simple, upgrade the tails etc, place the separated cooker (on left) spur in there and the middle spur, however the fused switched spur on the right is a separate feed from the main fuse as its the customers economy 7 night rate etc, now its got an 80amp fuse in it which i have already discovered is too high so what im thinking of doing is getting a CU big enough to place on the end another main switch so i can bring the feed tails to it then load a 63A circuit breaker for the economy 7. What do you think? or can i buy a CU that already has the facility for a separate main switch and circuit breaker on a split load board that already has a main switch and rcd? (if you know the best way can you please show me where I can buy the best solution
Many thanks
Many thanks
