A heating engineer is due to replace the boiler that is located in a smallish cupboard at the front of my house. When the Engineer saw the boiler he commented on how close the consumer unit was to the boiler. Below is a diagram of the boiler e.t.c
The Engineer mentioned that he wasn't sure if there would be enough space to fit the new boiler with the CU where it was located and even if there was he was't sure if it contravened any electrical regulations. Common sense tells me that having something plastic and electrical (MCBs affected by heat?) near to something hot probably isn't a good idea
The CU is the old brown bakerlite type and a while ago I replaced the old fuses with MCBs. I was thinking while having the boiler replaced this would be a good time to have the old CU replaced and moved to a more convienient location (by a qualified electrician!). From looking at the existing setup it looks as though the CU could be moved (left and down) without having to get Electricity Board to move meter or tails.
The only problem I can see with moving the CU is the cables that run to the ring circuits upstairs would have to be extended or wiring from CU to junction boxes upstairs replaced. Is it possible or correct to extend these cables when moving a CU? Obviously having to completely replace the wiring up to the junction boxes makes this a much larger and costly job.
I would be interested to hear from anyone here who knows a bit more about electrics than I do on this.
Thanks in advance
Martin
Thanks in advance
Martin
