you will of course have to comply with building regs [insulation strength ventilation etc]
i also believe you need permission to alter the front profile or appearance
Planning Permission is not required to insert a new window or door opening providing any upper floor window in the wall or roof slope forming a side elevation of the dwelling are glazed with obscured-glass (level 4-5 obscurity) and are fixed into a non opening frame (unless the opener is more than 1.7m above the floor of the room in which the window is installed).
