cooker and hob installation help please
13 Jul 2005
Lancashire
Ok ive bought a new single oven and a ceramic hob
My kitchen had an old cooker in it, but this wire is only the red and black ones, but has its own designated plug socket
Could i wire the hob into this still?
Also the cooker has a flex already with a plug connected, can this be plugged into any mains socket?
Cheers for help
Thats not a problem so long as there is also an earth (cpc)
but has its own designated plug socket Could i wire the hob into this still?
Depends on the csa of the circuit cable & the hob rating (Kw)
It could but I always put the oven/hobs on their own circuit via a cooker isolation switch, even if they come with flex & plugs.
says overall power is 6700
also how would i check there is an earth?
sorry if that sounds dumb
Hi Marky
Not to put a downer on you .. but if you are that unsure as to what an earth (cpc) is then I would suggest for your own safety , ( and that of your family ) that you employ a qualified sparks to check your circuit and connect appliances . Your life is worth it .
As the manufacturers instructions state that the appliances should be installed by a competant person . If a fault developes on your new appliance and it has not been installed correctly any service engineer that you have called out will most likely refuse to touch it , and also your warranty will be be invalid ( check your instructions ).
Hope this helps .
Phill
Do not cut off the plug and wire the cooker dirctly into the cooker connection unit. This will invalidate the warranty of the appliance.
Oh yes it will!
Wire the hob to the cooker outlet point behind the cooker
Plug the oven into a 3-pin socket.
For this purpose I would wire a single socket to the cooker outlet point. This means both the oven and hob are isolated by the cooker control switch above.
