kevplumb said:B.O.B go away you pillock
if you where reg you would know
ChrisR said:For a cooker; Leaks, clearances/spacings, ventilation, flame picture and stability, gas rate/pressure, stability/bypass rate, safety devices, doors hinges /seals etc, levelness, ignition, external factors, hose type/condition and bayonet height/orientation. Pipework etc as with any other appliance.
ie much the same list, typed before I wondered if you were a spoof.
fitz1 said:if its tennants property , visual check only.
Not at all - they're only checks, most of which would be done inside a minute. Which would you not do!thats a service chris
ChrisR said:Not at all - they're only checks, most of which would be done inside a minute. Which would you not do!thats a service chris
Couple of minutes for a gas rate, and you go off and do something else while the ovens warming so you can check it goes to bypass ok.
