OK - so that's the cooker, and the primary reason for the problem. However ....... and found the live was serverly burnt. ... On closer inspection, I found the neutral had welded itself to the live. So I took it off, snipped it back as luckily there were enough slack on the cable, and re-did the wires and this time I sleeved the earth as there wasn't anything on it before. ... Oven works fine. It just so happens that this day, 10 years after the cooker was installed, the insulation finally gave way probable chaffing I guess.
I'm afraid that doesn't make much sense to me at all. You again seem to be implying connections between the two circuits - which is worrying!Before I reconnected the cooker I switched the sockets on and volt checked the red and black. 0v. I then switched the cooker on at the CU and 240v was there. Bingo! ... The only reason I thought for the down stairs sockets going was there is a cable behind the oven, near this box that is fed from a fuse spur of the ring main, to power the cooker hood. But it's weird that the fuse didn't go in the FCU, just the MCB. You can see the cable going across the wall in the bottom photo. Hope it all makes sense.
Kind Regards, John
