Bob,
What is the accepted method to connect the hob and oven,both of which will be within 2metres of the CCU?Do I need to be running a 10mm and a 6mm across the house to feed them,as plugwash suggested.Should I use two 45amp isolators? Space is a bit limited on the wall and I don't really want it full up of sockets,a bit of a job tiling afterwards! even though I will remove all the sockets and refit them afterwards for neatness.I have got to get in 3 double sockets,2 3amp fused switches for lights,1 3amp fused switch for chimney and whatever is required for the oven and hob!Is one 10mm cable to the CCU and two out of it OK (both 10mm if possible to get them in)or two cables,one 10mm,one 6mm with 2 45amp isolators?
