Cooker Hood Stud
19 Dec 2015
Hi all
In process of installing a cooker hood and there is a vertical stud right in the centre line.
I have around 100mm either side of the stud which is not enough for the 125mm hole I was going to make for ducting.
Apart from drilling through stud (which is not ideal as this is what hood is attached to), only thing I can think of is to get an adapter to convert to rectangular ducting and pivot 90 degrees. Something like this
Any other ideas?
Luke
Cut hole as wide and long as the chimney cover allows and use a flexible mylar duct and squeeze it into the shape of the opening.
If that's a stud wall, ensure any vapour barrier is resealed.
Thanks for reply.
can flexible ducting flex in this way- I thought it could be used around corners but maintained the circular profile (if that makes sense)
